1/4" vacume line
1/4" vacume line
hey, i'm installing my supercharger and it calles for installing a tee where i cut a 1/4" vacume line. problem is i can't finde this vacume line , it's suppost to be located on the top rear of the motor. the lines that i see are all hard plastic and i don't think that i will be able to install the tee w/hard plasic lines, i'm looking for rubber lines are there any near this location if so where and if not what can i do about this? thanks for any advice..
RE: 1/4" vacume line
for the bypass valves i just connected both bypasses with 2 vacuum lines and a t fitting that i spliced before the connector of the red plastic vacuum lines. its hard to miss, i used the upper intake vacuum line upfront towards the tb. the connecters for the vacuum lines are 2 into one and you can just pull out one end (the single end not the double) and connect a small piece of vacuum hose with a t spliced in it. then just put a hose running from the bypass to the line you spliced in at the intake vacuum. sorry if that go confusing, just find one of the intake vacuum line 2-1 connectors and splice into that.
jwog666
12-27-2021 08:09 PM
Matt's 95 Stang
10-05-2015 07:16 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
