brake problem
Old 05-28-2006, 08:48 PM
jpmustanggt
jpmustanggt's Avatar
Default brake problem
Ok, I just got done lowering my car, but while we were lowering it we disconnected the front brake wires so they wouldn't be damaged if something were to fall off the car. When we got done we tried bleeding the brakes and nothing happened. When the car is not on you can pump the brake up and it will feel like it normally does but when the car is on you have to push the brakes all the way to the floor and it barely stops. Any ideas?????????
jpmustanggt is offline
Old 05-28-2006, 08:52 PM
sprostang
I ♥ Acer
sprostang's Avatar
Default RE: brake problem
Didn`t you get any fluid out when you bled them?
Is the fluid topped off in the master cylinder?
sprostang is offline
Old 05-28-2006, 08:57 PM
jpmustanggt
yep and yep!
Old 05-28-2006, 09:00 PM
sprostang
I ♥ Acer
sprostang's Avatar
Thats weird. I would bleed the master cylinder and then do the calipers again and go from there.
Old 05-29-2006, 02:35 AM
monkeydude3
monkeydude3's Avatar
sounds like you didn't bleed um right.... you gotta pump the pedal 3-5 times, crack the bleeder screw let the fluid spray and quickly close it. you will have to bleed all 4 wheels if you want it to turn out best...
and why not get a bunjee cord or a peice of coat hanger to hold up the calipers? always works for me if i can't lay um somewhere
monkeydude3 is offline
Old 05-29-2006, 03:37 AM
jpmustanggt
Well we did get a cord but the brake line was kind of in the way so we disconnected it, I'm gonna do all 4 tomorrow even though we only took them off on the front wheels.
Old 05-29-2006, 04:45 AM
racer02GTstang
racer02GTstang's Avatar
no matter what.. you have to start from the wheel furthest from the master cylinder and work to the closest one... otherwise it will not turn out right.
racer02GTstang is offline
Tivo304
08-28-2023 12:19 PM
SSRFUZZY
Members Other Vehicles
01-06-2016 08:22 PM
mungodrums
10-07-2015 04:01 AM
musnicki
09-23-2015 07:11 AM
Quick Reply: brake problem
