fuel injector cleaners
RE: fuel injector cleaners
Sea Foam is the best stuff ever. REad the side of the can and you will see that you can use it in your oil before a change and also can run it through your pcv valve line........that will instantly clean your engine out. White smoke will come out of you exhaust from the cleaning.
i got a can of it in the 'garage' waiting to go in. i figure after i replace the valve seals I'll do a full cleaning and then also replace the spark plugs while i'm at it.
a brand of fuel cleaner I have had good luck with is the lucas brand. I don't like their oil addtives (Or anyone's for that matter) but they have a great fuel cleaner that has given me good results
mrappe
09-26-2015 10:16 AM
