cam gears
RE: cam gears
ORIGINAL: jkm1987
i heard that when i install my comp cams i may have to buy cam gears because my cams may be pressed on are some models pressed on some not? or what mine is an 03 if that helps
RE: cam gears
Most, not all, were bolt on after mid '01. I believe the romeo motors had bolt on. Look at your VIN. The 8th character will be an X or a W. X = windsor, W = romeo. Go figure. The only way to be absolutely sure is to pop a valve cover off and see.
RE: cam gears
i was wondering the same thing when i was doing my cams, i think if you have a windsor, you dont have too, dont quote me on that, i think that is what scott from VT told me, i didnt need them (windsor), but it was like 75 or so if you do. look on vtengines.com and select a cam set then you will see the optional gear add on. actually i just looked for you, they are $69.
KingRando
10-02-2015 08:06 AM
junior04
09-28-2015 10:53 AM
