Removing my stock Midpipe help!
#21
RE: Removing my stock Midpipe help!
ORIGINAL: Sebski
How much would it be for a muffler shop to do a mid pipe install... guestimating?
#22
well in general how much would a shop usually charge... i was planning on doin my H pipe install but ive usted one to many knuckles in the past and recently developed a severe case of roid rage every now and then... jkz but does anyone know?
#23
ORIGINAL: Sebski
#24
Do you guys know if the stud that connects the bolt can be replaced? I was wondering if I could just remove the whole stud, and then buy another stud and put it back in. I didnt know if the studs were hammered inor what. Or if they are a dealership only part.
#26
ORIGINAL: czwalga00gt
Remove the K-member; you can get access to that bolt real easy doing it that way.
#27
If you go to Autozone ask for a stud remover,they have them in the loan a tool program.pay a deposit and get your money back when you take it back.You can use the stud remover if you get the nut off.It's like a socket that fit's over the stud and will remove it.Best thing to do is heat the nut drive a socket on then remove.PB Blaster is the best stuff on earth to get rusty bolts and nuts off!!!!!
#28
ORIGINAL: Yellow GT
#29
When I did mine I know the socket with the joint was on a angle.Could not budge with the 3/8 rachet had to break out the big gun to remove the nut.Autozone also has nutremovers made by Irwin but I think you might have tried them,kind of a backwards twisted socket that drives on to the nut.Other that cutting off the stud drilling it out witch would be a mother ****** I dont know?
#30
ORIGINAL: Yellow GT
