I washed the motor with the pressure washer
Old 06-07-2006, 03:31 AM
/\CHRIS/\
/\CHRIS/\'s Avatar
Default I washed the motor with the pressure washer
Hi
I have a 01 mustang gt 4.6 bullett and I pressure washed the motor. It used to run like crap after I pressure washed it. Now for a couple of days iv let it sit out in the vegas heat and it runs good. It just has a slight pop when I step on the gas. It sounds like one of the cylenders isent firing all the way. I was going to replace all of the ignition coils but a mechanic at my work told me to let everything dry really good. It just has a slight pop on one of the cylenders when I rev it. I was told it was probably the pcm that got some water in it. What are some things I could do to make the engine run better. I changed the spark plugs and took allot of stuff apart and blew it with air and it still has a slight pop. Could it be the egr vaccum regulator? Could someone let me know what to check?
Thanks,
Chris
/\CHRIS/\ is offline
Old 06-07-2006, 03:35 AM
rjgstang
rjgstang's Avatar
Default RE: I washed the motor with the pressure washer
man, the boots on the coil packs allow crap to get down in to the plug fairly easy so you prolly got a little water down in it
rjgstang is offline
jwog666
12-27-2021 08:09 PM
jerrytubes
10-23-2015 12:11 PM
UrS4
10-03-2015 06:23 AM
Explosive
10-02-2015 07:45 AM
logan409
09-26-2015 07:43 PM
Quick Reply: I washed the motor with the pressure washer
