Intake manifolds, aluminum or plastic
Old 06-07-2006, 04:53 PM
70 MACH I
70 MACH I's Avatar
Default Intake manifolds, aluminum or plastic
I know it's been discussed before but, for instance, the typhoon intake is aluminum, looks alot like a stocker, yet is claimed to produce 20HP more than a stocker. Are the runners larger than a stocker? Is the intake extrude honed, or cast in lost wax to provide a smooth surface inside? What I'm driving at is, a plastic intake can be made cheaper, insulates better against heat soak than aluminum, and already has smooth surfaces inside the runners. I'm not comparing to the P-51 intake which is radically different in design, but if you were sticking to NA, wo nitrous, couldn't a plastic intake reconfigured yield even more HP?
John
70 MACH I is offline
Old 06-07-2006, 06:43 PM
2000GT4.6
2000GT4.6's Avatar
Default RE: Intake manifolds, aluminum or plastic
ORIGINAL: 70 MACH I
John
The situation is that the stock manifold is already a very good one. It makes power all the way thru the band that the stock shortbock can handle.
Unless you plan on building the motor and the shortblock, or you have a blower/turbo car, you will not see large gains by switching out to a aftermarket intake manifold, and you will almost certainly loose power on the bottom end of the curve.
2000GT4.6 is offline
Old 06-08-2006, 10:24 AM
70 MACH I
70 MACH I's Avatar
Thanks man, that kinda confirms my line of thinking.
John
Vrooom
02-21-2016 05:25 PM
Luke9222
10-22-2015 11:55 PM
uberstang1
09-20-2015 06:42 PM
Scottyboy187
SVT Forums
09-13-2015 10:23 PM
09-01-2015 08:16 PM
Quick Reply: Intake manifolds, aluminum or plastic
