IAC VAVLE
IAC VAVLE
my car has been making a vibration sound and it has been idleing toooooo low and the rpms have been dropping too fast. even at normal temp and everything. someone told me it was my iac valve, what do yall think. need help . thanks
RE: IAC VAVLE
can be the IAC valve, also it could be the DPFE sensor, i had the same problem i cleaned the IAC valve and kept doing it, a couple of times when i was driving on 5th when i pushed the clutch, the rpm's got way low and the car went off, after like a month of driving like that the MIL light when on and the code was for the DPEF sensor (50 buck at o rellys or ford and it fixed my problem....
RE: IAC VAVLE
my car has just been doing this for a couple of weeks. RIght when i let of the gas is slows down. and when i push in the clutch the rpms drop really fast. and when i start it it will barely go up to 1000 rpm and the drop below 500 and turn off sometimes. this is really fustrating i have to get this fixed. so any more ideas of what it could be??????????
