Spark Plugs Install
Spark Plugs Install
I just installed new plugs and boots on my 2002 GT. The job is really easy and took about 2 hours, without rushing. There is no need to pull the fuel rails! The coil packs just slip under the fuel rail - no big deal. I used a 3/8" spark plug socket with the built-in u-joint. Be sure to use anti-seize on the plugs, and dielectric grease on the boots. Torque the plugs to 11 ft-lbs. The plugs I used are: Motorcraft AGSF32PM. The boots are: Ford F7TZ-12A402-AA.
Dan
2002 GT, 5spd, Mineral Grey.
Dan
RE: Spark Plugs Install
Yeah, it runs great. Mine does not have plugs wires, though. Not sure when Ford switched. Does someone know? Mine has boots only. Each plug has a coil on top, with a springy thing inside the boot...
