Suspension, alignement, + extras
If my alignment is off and currently sways lightly to the right. should i get the alignment fixed and checked by ford before i install my shocks/struts/and springs?
Also, should i do my c/c, bumpsteer and x2 ball joints all at the same time? or after i install the shocks and springs and align. than get the alignment done again?
Im goin with a 2in drop on adjustable shocks. is there any other important parts i should buy? like tie rod ends or something? I want to make sure the suspension is ****ing tight and has no problems? TECH GUYS let me know whats up?
RE: Suspension, alignement, + extras
while were on the topic, my car is in the sig and i was about to get Sportlines on top of alot of other things. I know that i need C/C plates, and im having it all installed at a shop. Question is, since my cars all stock, are there any other important basic suspension mods i could do while im at it? Suspension is the one area i dont know alot about. I'de appreciate any help. Thanks.
my steering wheels shakes like crazy when i brake. it shakes a little when just driving. my alignment was just done and i had my brakes checked out and my mechanic cant figure out why my steering wheel shakes.
If your steering wheel shakes like crazy when you hit the brakes then your front brake rotors are wraped and need to be either turned (cut on a brake lathe) or replaced if their to thin to turn.
but he said a mechanic checked the brakes and said everything was fine...get a different mechanic? or could it be something else?
i also have vibration during braking.
