HElp again plz
HElp again plz
my car has been making a vibration sound and it has been idleing toooooo low and the rpms have been dropping too fast. even at normal temp and everything, and when i let of the gas the car immediatly slows itself down. It just started doing this for about 2 weeks. someone told me it was my iac valve. BUT yesterday i was in 5th and when i took my foot of the gas the car didnt slow itself down, i thought it fixed itself. But now when i push in the clutch the rpms go higher... and i will be stopped and i will be idling 1500 rpms for a minute then they will drop to 1000. Is this still my IAC vavle??????
RE: HElp again plz
ORIGINAL: racer02GTstang
well, my dumb friend i think cleaned it with water and paper towels.... im not so sure....
shut up, i cleaned it with engine cleaner. and it came out clear. And my car is still acting weird??
RE: HElp again plz
I would sugest buying a new IAC,, they are prone to causing problems related to RPM's idleing too low and high and also causing car to stall out and die when stopped,, i would think that if you cleaned it VERY well with carb cleaner and its still doing it.. my next step would be to replace..
