EIBACH SPRING INSTALL - HOW TO
Old 06-12-2006, 09:15 PM
djdalfaro
djdalfaro's Avatar
Default RE: EIBACH SPRING INSTALL - HOW TO
ok... so if i'm using a lift... i will also need a hydrolic jack, yes?
djdalfaro is offline
Old 06-12-2006, 09:22 PM
mightyb28
mightyb28's Avatar
Yep. I think a lift is over-do for such an easy job, but yes you will need a hydrolic jack that is tall enough to get to the control arm.
mightyb28 is offline
Old 06-12-2006, 09:29 PM
djdalfaro
djdalfaro's Avatar
but with a lift and four guys I can get all the wheels off in no time flat... then maybe lower it back down to stock height, and use the jack?
Old 06-13-2006, 05:09 PM
mightyb28
mightyb28's Avatar
Default UPDATE
Your call, but i used a tire iron and got the wheels of super fast. Make sure you don't strip the threads on the lugnuts or the wheel hub.
I also left out a very important point.
When you are laying in the new springs look at the lower control arm and you should see a notch. This notch is where the spring needs to sit. So rotate the spring till the pigtail is sitting pritty much next to the notch.
Next lower the car to the ground for the springs to settle.
Lift back to jack stands and tighten down the bolts.
Eibach told me that a big issue of springs not settling is because the pigtails are not up against these notches.
So pay attention kids
Old 06-13-2006, 06:16 PM
tripsevn7
Moderating with Angels
tripsevn7's Avatar
Default RE: UPDATE
thanks for the write up. did you snap any pics??? if so i will wait to move this up top until you post them, if not i will move it now
tripsevn7 is offline
mtgldr
02-03-2024 09:00 PM
PullTab
10-30-2015 08:46 AM
RWHEELS
09-05-2015 03:42 PM
Luke9222
09-04-2015 06:46 AM
09-01-2015 08:16 PM
Quick Reply: EIBACH SPRING INSTALL - HOW TO
