THese are so much better looking than FR500's
RE: THese are so much better looking than FR500's
ORIGINAL: David_K
right now im in american iron but im about to drop the 5 liter cammer motor in and run in AIX. im in the texas region.
NASA cost alot of money to race in. he with the deepest pocket always wins.
i was qouted $9500 for the bbs rk wheels and tires i ended up going with CCW wheels
CCW are nice wheels, the corba R's that you have an I have are pretty light for the price. I got mine for $505 shipped to my door and the fronts weight 24lbs. and the rears 29lbs. pretty light for $100 a wheel. If I where you, get an old lincoln mark 8 take that motor its the same motor as 96-98 cobras except the intake manifold. That Aluminum block was made by the same manufacturer as Ferarri, it can handle 1500hp. Have that motor machined and put a new rotating assembly in, either a high compression NA motor or for forced induction. Then get the tubular k-member and A arms. carbon fiber hood, you will save like 240lbs. off the front end. I see you have a cobra already, you may already have the perfect motor. I dont know what you got in there but you would already be set. You can get a mean motor for 14k. Dont wast your money on a crate motor. Your going to race it so you already voided the warrenty. Tell me your set up....
ORIGINAL: David_K
of course the ford gt wheels wont fit on your mustang
500 bucks for 4 18 inch aftermarket wheels.....
i got the cammer motor for $5500 and just got a stroker in it so its a 5.3L with fr500 heads fr500 cams and its getting a sullivan intake manifold.
1997 Mustang SVT Cobra
CURRENT ENGINE 322 hp / 312 trq
4.6L DOHC V8
BBK CAI
BBK 62mm TB
BBK LT headers
BBK X pipe
stock gutted mufflers
BBK UDP
A/C deleted
P/S deleted
Ported heads and intake
SHM high performance valve springs
V10 Water Pump
V10 Radiator
95 Cobra R "DE-GAS" Bottle
NEW ENGINE awaiting install
FRPP 5.0L "CAMMER" crate engine
5.0L big bore motor
FR500 heads
FRPP high lift camshafts kit
FR500 intake manifold
DK Motorsports stepped lt headers
DK Motorsports 3" X pipe
Dynomax race bullets
Suspension
Griggs GR40 Tubular K Member
Griggs GR40 Tubular A Arms
Griggs GR40 Coilovers (800lb sprigns up front and 500lb springs in rear)
Griggs GR40 Caster/Camber plates
Griggs Strut Tower Brace
Saleen/Racecraft Front Sway Bar
Kenny Brown Full Length SubFrame Connectors
Maximum Motorsports Adjustable Spring Perches
Maximum Motorsports Adjustable Rear Sway Bar (2 link)
Maximum Motorsports Adjustable Rear Lower Control Arms
Maximum Motorsports Differential Brace
Maximum Motorsports Full Bushing Set
Brembo Cobra R Front Brake Kit
Bear Eradispeed 13" Rear Brake Kit
Focus RS Brembo 4 piston calipers for the rear
Drivetrain
Tremec 3550
Fidanza Aluminum Flywheel
Stock Clutch
B&M Shifter
3.73 Gears
Interior
Sparco EVO (Driver)
Sparco EVO3 (Passenger)
Schroth 6-Point Harness (Driver)
Simpson 5-Point Harness (Passenger)
8-point cage modified to conform with NASA rules
Halon Fire Suppresion Sprinkler System
Cool Suit Personal Cooling System
Sparco Steering Wheel
MISC
22 gal Cobra R fuel cell
255lph fuel pump
External Oil Cooler
External Transmission Cooler
External Differential Cooler
17" White 95 Cobra R wheels
275 Toyo Proxis RA1
Motul Lubricants
1998 Mustang Saleen SA-15 Speedster
4.6L SOHC V8
90mm SCT "BIG AIR" MAF
Accufab 75mm TB
ASP 12# pulley
Bassani Mid-length headers and mid pipe
Saleen heads with reground PI cams
3.55 gears
Saleen suspension/brakes/body kit/etc
4.6L DOHC V8
BBK CAI
BBK 62mm TB
BBK LT headers
BBK X pipe
BBK UDP
A/C deleted
P/S deleted
V10 Water Pump
V10 Radiator
5.0L big bore motor
FR500 heads
Suspension
Drivetrain
Tremec 3550
Stock Clutch
B&M Shifter
3.73 Gears
Interior
Sparco EVO (Driver)
MISC
255lph fuel pump
External Oil Cooler
275 Toyo Proxis RA1
Motul Lubricants
4.6L SOHC V8
Accufab 75mm TB
ASP 12# pulley
3.55 gears
Damn you got one damn nice car. Frankly the nicest car on this forum. I dont car for drag racing, road racing is my heart it. Good for you.. You have some mightly deep pockets!!! Sounds like a real nice setup. Im suprised your not using a 3 link rear suspension, and keeping the 4 link. I have such horrible traction, with a 4 link. I am getting a torque arm, coil overs and watts link, next on my car.
ORIGINAL: David_K
4.6L DOHC V8
BBK CAI
BBK 62mm TB
BBK LT headers
BBK X pipe
BBK UDP
A/C deleted
P/S deleted
V10 Water Pump
V10 Radiator
5.0L big bore motor
FR500 heads
Suspension
Drivetrain
Tremec 3550
Stock Clutch
B&M Shifter
3.73 Gears
Interior
Sparco EVO (Driver)
MISC
255lph fuel pump
External Oil Cooler
275 Toyo Proxis RA1
Motul Lubricants
4.6L SOHC V8
Accufab 75mm TB
ASP 12# pulley
3.55 gears
4.6L DOHC V8
BBK CAI
BBK 62mm TB
BBK LT headers
BBK X pipe
BBK UDP
A/C deleted
P/S deleted
V10 Water Pump
V10 Radiator
5.0L big bore motor
FR500 heads
Suspension
Drivetrain
Tremec 3550
Stock Clutch
B&M Shifter
3.73 Gears
Interior
Sparco EVO (Driver)
MISC
255lph fuel pump
External Oil Cooler
275 Toyo Proxis RA1
Motul Lubricants
4.6L SOHC V8
Accufab 75mm TB
ASP 12# pulley
3.55 gears
What are you gonna do with the old 4V?
