Which would you recommend first?!?!
RE: Which would you recommend first?!?!
Ok, I think I'm gonna drop it first.
That way I can just replace the control arm bushings while I'm in there.
The car will look, ride, and handle better than before.
I am definitely going to get gears, just can't decide if I want a catback/mid-pipe first!
But I'll save that question for later......
Thanks guys,
Vince Woska
PS: check me out here: http://www.brocksperformance.com/champions.htm
Thanks guys,
Vince Woska
Ok, now that I know you have no fear of going fast.......and nailing corners......... definitly reinforce the car FIRST. All those braces I mentioned, and maybe even a 4point cage. I had an 89 LX that I literally cracked my dash down the center goin around a corner, 90* off camber that I hit at roughly 60. These cars flex A LOT, as for shocks/struts get adjustables, (koni,tokico) that way youre not stuck with only one rate of dampening. Then do the exhaust, gears, etc.
-P.
-P.
Sounds good but where are you really gonna use all that suspension??? Dont you think that straight line speed would be more practical for an everyday driver? I meen your not racing on a track are you?
I would definitely FIX problems before worrying about exhaust, gears, or anything else. Fast and loud doesn't do you any good if the vehicle isn't in good mechanical condition first. Besides you can kill 2 birds with 1 stone by getting the handling you desire while at the same time eliminating the old, worn out parts. I personally went exhaust first, but I only have 27k now, and I have had the Magnapacks for 6 months. BTW...I love them and would recommend them to anyone.
ORIGINAL: bsteen81
-P.
ORIGINAL: bsteen81
Well, if you wanna look like your fast drop it. If you wanna be fast, add gears. Unless you plan on racing around a circuit track, I wouldnt touch the suspension for a while. Also, if you do go with gears, go with the 3:73 if you are gonna want big HP in the future, and 4:10 if you are just gonna do full bolt-ons or close to it. You will lose 1st gear if you go with 4:10 and high HP.
http://www.stangnet.com/Tech-Article...d-Answers.html
ORIGINAL: mustangman02232
you have obviously had no gear experience with the T-3650, if i had his exact car, i personally would put 4.30s in there
ORIGINAL: bsteen81
Id say put a 3.73 in, its a good all around gear, decent for the strip, good for the street. Just my opinion, Im not a drag racer, so I dont go extreme with my gearing. When I do build a dedicated strip car itll have 4.56 gears.
-P.
