just got a diablo tuner
Old 06-15-2006, 04:08 PM
damdanger
damdanger's Avatar
Default just got a diablo tuner
is there anything i should know, am i gonna have to run a certain gas, i bought it because i bought gears and im plannin on doin a bunch of little mods, i just wanted to know before i screw anything up
damdanger is offline
Old 06-15-2006, 04:14 PM
shadowfoxx
shadowfoxx's Avatar
Default RE: just got a diablo tuner
if you install the diablo tune into the car you will need to use premium gas... plus while your at it you should turn off the traction control and max out the spark advance at both ranges to increase hp.
shadowfoxx is offline
Old 06-15-2006, 04:22 PM
damdanger
damdanger's Avatar
ok cool, i figured i would rather spend 280 on that then a 100 on a calab. since im goin to an offroad pip figured i would have to fix some sensors, why do you need to use premium, im just curious on the affects
traction control
premium gas
advance spark
anything else i need to add to the list
i have 4.10 gears and CIA coimin for it
Old 06-15-2006, 05:46 PM
Ostang04
Ostang04's Avatar
it affects the advanced spark you should max it out and use 93 if you can, if you can only get 91 you may have to back it off a little. The higher octane helps to prevent detonation. If you get pinging (a knocking sound) you need to back it off. If you have 4.10's you can change that under the Axle screen.
Ostang04 is offline
Old 06-15-2006, 06:36 PM
shadowfoxx
shadowfoxx's Avatar
ORIGINAL: Ostang04
^^ yep.. what he said ^^
Old 06-16-2006, 03:23 PM
damdanger
damdanger's Avatar
ok i just got all my toys in, what else should i do, is switching to premium on a high mile(113k) car gonna hurt me?
Old 06-16-2006, 04:22 PM
Smooth_J
Smooth_J's Avatar
ORIGINAL: damdanger
In short - it won't.
On another note...if you are running full spark adv though, I recommend going to a cooler plug.
Smooth_J is offline
Old 06-16-2006, 06:08 PM
JimboGT01
JimboGT01's Avatar
what do you mean by a cooler plug?
JimboGT01 is offline
Old 06-16-2006, 06:23 PM
LvGordo
LvGordo's Avatar
ORIGINAL: JimboGT01
plugs come in heat ranges, i run autolite 103 (cooler than stock) for my FI cause of the advanced timing.
LvGordo is offline
Old 06-16-2006, 06:31 PM
yuengling910
yuengling910's Avatar
i thought that you retarded timing for forced induction?
also, not to highjack, but i also just ordered a predator, and plan on advancing the timing. i know to use 93, are colder plugs a definite? how many heat ranges cooler should be considered?
yuengling910 is offline
Quick Reply: just got a diablo tuner
