the widest tire dimensions....
RE: the widest tire dimensions....
ORIGINAL: 04BlueGT
17x10.5 will hold 335, but you'll have to roll the fender lips to fit them. 315s will fit without modifications.
18x10 I have no idea.
ORIGINAL: gt96stang
Then explain to me how code3 didn't have to roll his fenders or remove his quad shocks with his 335's.. Plus he had a pro-kit on his car.
ORIGINAL: 04BlueGT
Ceekay, yes, even lowered, 315s will fit. If you have CAs, then the quads don't matter. You can leave them or remove them.
I don't know about 18x10s. I've never researched those. However, if a 1.5 inch drop with 17s doesn't cause an issue, then I doubt a 3/4 inch drop with 18s will. Still, I cannot be sure.
Bump?
EDIT: I just did some quick searches and 315/30/18s should be fine. But DAMN, those tires are over $325 each! That's pricey to me.
Bump?
ORIGINAL: ceekay84
cheapest 315 tires on 18s are 325ea???
Look here: http://www.tirerack.com/tires/Compar...=All&x=87&y=10
ORIGINAL: 04BlueGT
He DID roll his rear quarters (50% or so) and removed the quads when he had the 335s on. Ask code. He's the one I learned about this from.
ORIGINAL: gt96stang
ORIGINAL: 04BlueGT
