humming noise in front drivers side
OK where to start, I have a humming noise in the front driver side, checked the tire no problems, replaced caliper, pads, rotors, hub spins freely I have no clue can anyone give me some suggestions please[sm=helpout.gif] Also the noise goes away when I steer towards the left then comes right back when going straight or right??????????
RE: humming noise in front drivers side
Wheel bearing hub. With the new style bearing/hub asembly most of the time they want make any noise with out a load on them, unless their real bad. When you steer to the left it takes the load off that corner, when your straight ahead or turn right it puts the load on it.
It does sound typically like a wheel bearing. However, if that does not fix it, it'd be a good idea to check your ball joints as well...
JT
JT
