? on rear end play
Old 06-16-2006, 03:13 PM
wildazme
wildazme's Avatar
Default ? on rear end play
I had my car in the shop today having brakes done and the mechanic told me i have about a 1/4 inch of play on the drivers side rear end and that im going to have to have the rear done soon. is this true? or do the 98 model stangs have a lil play in the rear?
wildazme is offline
Old 06-16-2006, 03:14 PM
monkeydude3
monkeydude3's Avatar
Default RE: ? on rear end play
how does he figure, is it rotational or is it like an in/out of the axle??
nice time too!
monkeydude3 is offline
Old 06-16-2006, 03:39 PM
GodAmGT00
GodAmGT00's Avatar
If it's on the in/out, then it could be a potentially bad thing... Since you have a pin, that goes through the LSD, and basically prevents the axles from going in too far, and then you have C-Clip style washers that hold the axles in, there should be minimal play in the axle's in/out..
Now, if it's up and down, the you have a more serious problem, since the axle bearings are usually pretty tight, and hold the axle in w/ minimal play... If it's going up and down a 1/4in, it could also mean that your LSD, gears, bearings, and any Raceways that are involved, are probably toast...
That's just a theory.. You should have someone look at it, like a Trans-shop, or a good friend who knows about cars...
JT
GodAmGT00 is offline
Old 06-16-2006, 04:15 PM
wildazme
wildazme's Avatar
well the play is in and out not up and down. im going to a tranny shop soon just wanted to throw the question out there.
wildazme is offline
musnicki
09-23-2015 07:11 AM
Dragonus18
09-09-2015 01:21 AM
iamgobono
09-03-2015 12:37 PM
cbird1177711
09-02-2015 08:51 PM
09-01-2015 08:16 PM
Quick Reply: ? on rear end play
