Fuel Pump Re-Wiring
Old 06-17-2006, 06:45 PM
blackbetty01
blackbetty01's Avatar
Default Fuel Pump Re-Wiring
I bought a Walbro 255lph pump and it is maxing out at about 4500rpm's. Now I bought a Focus 310lph pump, my tuner recommended rewiring the pump with a 10-12 gauge wire to increase the voltage. Is that necessary? Has anybody used the Focus pump without rewiring and acheived good results? How much rwhp do you have? Thanks in advance.
blackbetty01 is offline
Old 06-18-2006, 10:34 AM
blackbetty01
Default RE: Fuel Pump Re-Wiring
Here are more details.
The fuel pump power wire is the one that runs from the inertia switch to the FPDM, should I cut that and install a relay to feed power to it from the battery? Should I use 10 or 12 gauge wire? It looks like the stock wire is about 16-18 gauge. I want to do this myself because I am going over budget with this setup.
Old 06-18-2006, 11:49 AM
yuengling910
yuengling910's Avatar
do you know the max current draw on the pump? that should tell you what size wiring to run.
yuengling910 is offline
Old 06-18-2006, 12:53 PM
blackbetty01
Currently the power wire looks like a 16 gauge wire. I am just concerned with if the Focus pump will receive enough power to do it's job adequately once I install it.
GimpyHSHS
19
12-19-2023 01:12 PM
Bokeo
10-10-2015 08:28 PM
b8checker
10-08-2015 12:55 PM
Sixx
10-05-2015 07:36 PM
mrappe
09-26-2015 10:16 AM
Quick Reply: Fuel Pump Re-Wiring
