5.4L block????
5.4L block????
Hi guys,
i was wondring if this is possible? just an idea i dont think that im going to do it, but just want to know if its possible, is possible to swap my 4.6 block with a 5.4L? i mean just the block of 5.4, would my original heads fit? and what about the fueling system does it have to be changed such as injectors, intake,etc?????????????????????
RE: 5.4L block????
they use the same heads.....prepare to spend alot of money i ended up spending about 2,900 after everything..... now i wish i would of just s/c the 4.6.........save urself trouble and save up for the a s/c......the 5.4 is all torque 0-60 is nasty but after that it dies off.....just got my cams, but will see.......
RE: 5.4L block????
ok guys i have a question are u talking about 5.4 sohc or 5.4 dohc becuase there's a huge differance!!!!! the sohc puts out 280 and the dohc puts out 340 i believe, the money u will spend on the dohc will be more expensive then a s/c.....just trying to put the dohc into a mustang will be had enought, i had to hammer my bbk shorties to get them to fix i could only imagen if it was the dohc.......and the cheapest i found the dohc 5.4 was 3,600 at a salvage.
Matt's 95 Stang
10-05-2015 07:16 AM
