Gear Change?
Gear Change?
I just recently got smart....I converted from a rice burner to an 02 gt. It has 40,00 miles. It already had a CAI. It is an auto and I can be cruising about 35 and floor it and the tires will chirp. This is done with brand new tires. Is this normal for an auto with stock gears or do you think the previous owner had already swapped out the gears?
RE: Gear Change?
I am asking this queation because I did not want to go thru the expense of having the speed shop do it and it be done. I have rode in a couple gt's in the past and none of which shifted so hard
RE: Gear Change?
umm no, i can chirp second in my stock 6 shooter, might have a shift kit though cause i dont think there is enough line preasure at WOT to chirp second without going D-2-D, im betting they are stock, and get them swapped for some 4.10s
RE: Gear Change?
i have an 01 automatic gt and a 96 automatic gt the 96 has a shift kit and it still doesn't do that, neither does the 01 gt, i don't have gears yet so i wouldn't know but i would say something done to it, unless you are talking about when you have it in first and than shift into second b/c it does it than, i don't believe that about a v6 my g/f has a 2003 one and it would do anything but be really slow
RE: Gear Change?
ORIGINAL: 01and96stanggt
RE: Gear Change?
Not doing anything but cruising about 35 in drive then flooring it and it will chirp the tires. I talked to Martel Bros and they will do the 4.10 gears for about 300. Just did not want to wast their time, my time or my money.
RE: Gear Change?
oh ya her car will chirp if you shift from 1-2 pretty good, but he was saying just going 35 miles per hour and flooring it, without shifting if i understood him right
RE: Gear Change?
Well I think I will put my money into something else for right now then.....I am assuming it has had some mods done beens I am unable to find anyone who has experienced this with stock gears.....Thanks a great deal....
ORIGINAL: mustangman02232
im not sure on that though, it might have been tweeked on, i dont know anyone who has been able to break the tires loose stock but even with the 3.73s one of my friends was stupid enough to get they bark really good
RE: Gear Change?
ORIGINAL: TX02GT
