the diff. between wet and dry is that wet injects the required amount or nitrous though the nossle, and dry spikes the fuel pressure to supplie the extra needed
to make it simple, you could say dry nitrus is more simplier, dry systems typically are injected into the intake(hence dry cuz no fuel is present), while wet systems are usually combined nitrous and fuel in manifold(hence wet because the fuel is present)
the diff. between wet and dry is that wet injects the required amount of gas though the intake, and dry spikes the fuel pressure to supply the extra gas needed
