A quick FYI for us MODULAR guys...
RE: A quick FYI for us MODULAR guys...
Dan,
If I'm not mistaken there is a hydraulic fulcrum, that supports one end of the cam follower, the other contacts the valve tip. The hydraulic fulcrum acts like a lifter in the sense that it maintains zero lash. The whole deal works like a second class lever. If that hydraulic fulcrum sticks or gets gummed up, you will get valve noise.
John
John
ORIGINAL: 70 MACH I
Dan,
John
Dan,
John
Here are the Hydraulic Lash Adjuster:
From here. http://www.seanhylandmotorsport.com/...edb3ced210478a
Also heres the Roller Rocker:
From Here... http://www.seanhylandmotorsport.com/...edb3ced210478a
From what I remember the part on the left where the resses is where the valve stem goes. The other side where there is a channel goes the hydraulic lash adjuster pushes up against. Then the cam rolls over ontop.
All these pictures were from Sean Hyland Motorsports website.
I think it's the other way around.. The domed, recessed part is where the HLA goes, as you can see the little port on the rocker arm, and the little nipple on the HLA. That's the oil port..
I think the reason our engines don't like going over 6500 RPMs is because the Rods/Wrist pins, not the valve train being Hydraulic..
Look at Hondas, OHC, yet their redline is 7800+ RPMs. Why?? Not immediately because of valvetrain, but because of the bottom end..
JT
JT
ORIGINAL: GodAmGT00
JT
JT
I'm pretty sure that most OHC cars use HLA's, since the technology is proven and inexpensive.. My old Pontiac had HLA's, and it was something like $15 for each HLA, and $8 for rocker arms.. Now, for a solid lash adjuster, I'm not sure... I'm not even sure how a solid one would work..
Would it have a separate manual adjustment rather than a automatic hydraulic adjustment??
Also, thanks for the pictures.. It will hopefully help others understand what is being mentioned here...
JT
JT
