Intermittent starting problem - suggestions?
Old 06-19-2006, 02:28 PM
diverguy64
diverguy64's Avatar
Default Intermittent starting problem - suggestions?
Here's a weird one... my 96 GT has what the dealer calls "an intermittemt" starting problem. Most of the time it flashes right up no problem, but every now and then you put in the clutch, turn the key and...nothing. Gauges, dash warning lights and everthing come right on but no starter. If you play with the clutch and keep the key turned, eventually it suddenly fires right up. Dealer has replaced the clutch cancel/safety switch, but the problem is still there. Ford can't seem to figure it out.
Any suggestions? I had to roll it downhill and pop the clutch to get it going this morning. It's becoming a real pain.
diverguy64 is offline
Old 06-19-2006, 02:30 PM
monkeydude3
monkeydude3's Avatar
Default RE: Intermittent starting problem - suggestions?
check the starter fuse and relay, and also it may be the starter solenoid itself within the starter... relays will cause this problem as will the internal solenoid
monkeydude3 is offline
Old 06-19-2006, 04:50 PM
Black_sunshine
Black_sunshine's Avatar
Does the weather make it worse?I had a 77 chevy did the same thing and it turned out to be a bad ground
Black_sunshine is offline
djbigskrilla
09-20-2022 01:04 AM
drfister
05-03-2018 10:38 PM
jjwinel78
08-17-2015 03:34 PM
KEM Motorworks
08-14-2015 10:13 PM
Pain.
08-07-2015 10:48 PM
Quick Reply: Intermittent starting problem - suggestions?
