on the diablo tuner i need to retard my timing i wnat to know what -1 and -2 means like how much is that in degress
I don't know. Just a guess. "Degrees" brother? And no, I'm not trying to be a smart ****. I've never used the Diablo before but timing is measured in degrees, so, it's a safe guess.
the timing stock is at 10 deg. the diablo only advances and retards at WOT so if your problem is at idle or under normal driving conditions then this wont help your problem
diablo measures there is percents not degrees....so - 3 does not equal 3 degees back it equals 3 percent and i wanted to knwo how many percent equals 1 degree,and i want to change it so when i use my nitrous at wot the timing is not advanced but retarded 3 degrees.
