Motor Mount
Motor Mount
So today i got new breaks, and then the mechanic asks if i have heard a clunck sound, and i said yes....summed up, the bottom left motor mount is broken. He said its 200 in labor to fix it, and i have to find the mount. Sooo does anyone think i can do it myself and/or where can i find the mount for my 97 gt.
RE: Motor Mount
search ebay for some poly motor mounts and yes you should be able to do the work. just put the car on jack stands. remove the mid-pipe. use a floor jack and a block of wood under the oil pan. remover the nuts off of the mount studs. raise the motor, unbolt the mounts from the block and then reverse the process.
RE: Motor Mount
So, for Future reference:
If someone says "You should replace the LOWER LEFT Motor Mount," when indeed, there is no LOWER Left, just a LEFT, look them straight in the eye and say "Show me.."
JT
JT
