rebuilt engine
Old 06-22-2006, 03:21 PM
monkeydude3
monkeydude3's Avatar
Default RE: rebuilt engine
http://cgi.ebay.com/ebaymotors/Mod-4...spagenameZWDVW
is this a good kit???
hopefully there will be some around like this when I have the money to buy my engine parts, this is exactly what i need
as i plan to supercharge after the rebuild
monkeydude3 is offline
Old 06-22-2006, 09:30 PM
monkeydude3
bump
Old 06-22-2006, 09:39 PM
blueherd02gt
blueherd02gt's Avatar
hey monkeydude if I were you I'd call the # and talk to somebody at that shop and get them to sell you over the phone. Like really sell you on their product
blueherd02gt is offline
Old 06-22-2006, 10:19 PM
Rantheman
Rantheman's Avatar
what do you plan on doing with your motor because i don't believe you need a forged kit unless your running boost but i think it a little pricy but i don't know what your budget is you could get a stroker for a couple more 100 bucks
Rantheman is offline
Old 06-23-2006, 01:10 AM
monkeydude3
I wanna try to save my engine if at all possible, to keep cost low. I want a mild lope (equivilant of a stage 1 cam) and I want to boost the engine eventually
Old 06-23-2006, 01:48 AM
Rantheman
Rantheman's Avatar
if you are wanting to boost then a fredual moguel is not the kit for you you need to find either a set of 17cc pistions or stick with the 10.5 cc pistions and get a head the is not the pi head cc chamber of 43cc
Old 06-23-2006, 03:08 AM
monkeydude3
all right... much research will be done when the funding is there... thanks for the help
Old 06-23-2006, 07:17 AM
03zx2
03zx2's Avatar
any suggestions for a guy that wants to build their bottom end up for nitrous?
03zx2 is offline
Old 06-23-2006, 10:46 AM
4.698GT
4.698GT's Avatar
ORIGINAL: 03zx2
Forge the crap out of the motor and bump the compression.
4.698GT is offline
Old 06-23-2006, 11:50 AM
GodAmGT00
GodAmGT00's Avatar
The way things have been going on Ebay, I personally would have a hard time spending more than $100 on there, and NOT use an Escrow Service to mitigate the transaction...
George,
Personally, if I were you, I'd look at getting a decent used engine, low mileage, and just freshen it up. When I mean freshen, I mean replace a lot of the gaskets (oil pain, Oil filter housing, valve cover, plenum, anything that is prone to leaking), take some time to clean all of the crevices, and go over the wiring, replace vac. lines, and make sure that the engine is good to go.
You may want to also swap in some cams, and do the timing set as well.. I mean, I can atest to the durability of these engines, especially if you get a newer, PI engine from the get-go...
Another great thing about that, is that you can swap over the majority of your Accessories, and other modifications. That alone will save you loads of money....
Plus, after the swap, you can still pull your old engine apart, find out what was wrong and either fix it or sell it to defer the cost. Unfortunately, that takes a little time, but in the end, I'm sure you'll be more than happy...
Happy boosting...
JT
GodAmGT00 is offline
Quick Reply: rebuilt engine
