C&C plates: ATTN Code3GT
Old 06-24-2006, 03:26 AM
monkeydude3
monkeydude3's Avatar
Default C&C plates: ATTN Code3GT
Hey my UPR C&C plates came today, the basic ones... by looking at them they made me very happy, very heavy and very strong construction, very nice looking as well
Now just gotta put them in! I'm thinking about tackling this tomorrow, but I'm not sure...
Code, have you put yours in yet? You had said you were going to soon... not sure if you got around to it yet
Assuming it's just a direct swap, how long roughly should it take? I figure with jacking it up, getting the wheels off etc maybe a few hours?
George
monkeydude3 is offline
Old 06-24-2006, 03:31 AM
Rantheman
Rantheman's Avatar
Default RE: C&C plates: ATTN Code3GT
hey monkey sorry to budge in but are they a 3 bolt or a 4 bolt style
Rantheman is offline
Old 06-24-2006, 03:40 AM
monkeydude3
3 bolt style, I know people say the 4 bolts are stronger and stuff but right now i can only afford these and i'm not racin the car just makin it so my tires last longer... they will be good enough for me
edit: and you are not budging in if you are discussin what i'm postin about!
Old 06-24-2006, 04:57 AM
Rantheman
Rantheman's Avatar
well mine are a 4 bolt only mod i had to do was drill a forth hole but since yours is a three should be a direct swap. but i don't know what type it is mine uses a sperycial bearing
ORIGINAL: monkeydude3
Old 06-24-2006, 05:00 AM
racer02GTstang
racer02GTstang's Avatar
they should take maybe 30-45 minutes to install.... i did 4 struts/shocks on my car today in alittle under 2 hours with a couple 15 min breaks. although i used an impact. all you have to do is jack the car up, take the wheels off, and take off the upper strut bolts... then take out the other bolts... and drill through the rivet.
racer02GTstang is offline
Old 06-24-2006, 05:02 AM
monkeydude3
do I just let the strut/control arm/hub just hang there while i swap the plate?
Old 06-24-2006, 05:08 AM
monkeydude3
let me know... im hittin the sack, i will check back tomorrow, peace all
Diabolical!
Archive - Trades & Freebies
06-27-2007 11:26 AM
Diabolical!
06-27-2007 08:47 AM
ZW99GT
25
12-16-2006 06:17 PM
edified
06-30-2006 11:42 PM
laserred38
West
05-11-2006 01:54 AM
Quick Reply: C&C plates: ATTN Code3GT
