spring isolators
Old 06-26-2006, 09:21 AM
silverbullit02
silverbullit02's Avatar
Default spring isolators
I will be installing a eibach pro-system plus in the next few weeks. The question I have is I bought spring isolators for the system is there someplace they have detailed intallation instructions? If not could someone explain how to install? Also if anybody has this system what do you think of it?
silverbullit02 is offline
Old 06-26-2006, 11:58 AM
gtboy2k
gtboy2k's Avatar
Default RE: spring isolators
These are the instructions I used to install mine just this weekend. http://mustangworld.com/ourpics/fcar/steedaspring1.htm
gtboy2k is offline
Old 06-26-2006, 08:02 PM
silverbullit02
I 've already seen those instructions. I was talking about the isolators, the rear set I think, it has two flexable tubes that I have no idea what they are for.
Old 06-27-2006, 04:33 AM
djdalfaro
djdalfaro's Avatar
when you take off you're stock springs you will see... you slide them on the bottom of the spring... and it's the fronts with that tubing.
djdalfaro is offline
Old 06-27-2006, 05:34 AM
racer02GTstang
racer02GTstang's Avatar
do the poly ones actually do much? i just kept the stock rubber ones.
racer02GTstang is offline
Old 06-27-2006, 09:12 AM
silverbullit02
thanks
Old 06-27-2006, 08:08 PM
djdalfaro
djdalfaro's Avatar
the poly ones just don't wear out as fast, and are new...
GimpyHSHS
19
12-19-2023 01:12 PM
CS2007
06-25-2019 09:45 PM
Gene K
10-21-2015 11:37 PM
mungodrums
09-28-2015 10:54 PM
Quick Reply: spring isolators
