Shaker hood
Old 06-26-2006, 06:29 PM
Soaring
I ♥ Acer
Soaring's Avatar
Default RE: Shaker hood
ORIGINAL: M1ke
ORIGINAL: Soaring
I have an 03 Mach1. The hood doesn't shake. The engine moves, so you see the top of the EFI moving with the engine. The purpose is to add more cold air to the system. The air taken in by the EFI is added to the air coming in from the front, therefore giving you more air flow. Yes, both sources go through one air filter, but if you have a K&N filter, you are getting more air to the engine than with a single source. The Mach engine is a 32 valve DOH cam. The suspension is beefed up, especially in the rear where it is needed for traction. My nephew has an 02 GT, and he much prefers to drive my 03 Mach because of the added power and traction.
huh?? EFI what? isnt EFI electronic fuel injection and not the shaker scoop? but anyways the hood doesnt shake, you just have a different one if you have a mach1 or get the scoop for the gt.
air goes into the scoop (shake shake shake) which goes into the intake where air also comes in through the silencer and all that air goes into the engine.
boy this thread is getting confusing.
Well, if you have something other than EFI, you ain't got a 4.6. The air comes in on TOP of the EFI, but then is diverted to the passenger side where the air filter is.
Soaring is offline
BOB ROME
07-26-2023 01:54 PM
PaulH2
20
01-31-2016 09:48 AM
11-18-2015 01:34 PM
Urambo Tauro
10-05-2015 09:37 PM
ThatJuanStang
09-25-2015 08:01 AM
Quick Reply: Shaker hood
