Passenger kick panel?
I took a look under the passenger side to look for the kick panel and I couldn't figure out where it was. Can someone post a pic pointing it out for me? I'm looking for the computer unit to check if I have a chip. My diablosport tuner won't install for some reason.
RE: Passenger kick panel?
hears a pic for the directions i used to install my shift light. you have to remoive that push pin. get a hammer and get the side that you use to remove nails and slide that under it and pull. try not to scratch the panel though. befor you take off the panel you have to take off the running board panel. just pull that it will come right off and snaps right back in.
