pictures of heat shield for jlt rai
im tryin to get my heat shield on finally because i never installed it but it seems it wont fit. all it is is one bolt but it just seems like it will never fit in there nomatter what i do. soo if anyone has a pictures of their system with their heat shield on it will help me out alot. thanks
RE: pictures of heat shield for jlt rai
hey Master i just heard ur video and sounds pretty good, u running a mild cam? sounds bad ***.
and yeah u do have to modify it to make it fit. u might have to boar out the holes a little using a 3/8 stepbit.
Mine fit just fine. You only use the top mount from your old filter box. I bought new hardware for this and saved the stock hardware. You do have to push the bottom of the sheld under the filter and then pull it up to where it mounts.
though I had some shots of this but I must have deleted them.
ORIGINAL: wwmost
well i just gave up. iono why it wont fit in my car. i tryed to cut it also but it just isnt fitting. does it matter that much??
