fuel filter
06-29-2006, 04:25 PM
fuel filter
I just got a fuel filter from my dealer, I figured while I have the car up for the stupid clutch cable i'll do some good
anything special? It looks like the filter is bolted to a bracket, and then it has the 'quick disconnect' on each end... i have all the tools to do this, just wanting to know ifa nyone ran into anything while doing theirs
06-29-2006, 04:30 PM
RE: fuel filter
Its Preaty simple when i did it. Didnt have no probs.
06-29-2006, 04:31 PM
RE: fuel filter
cool.. maybe after work tonite i can put in my clutch cable, change that filter and go for a drive in MY car
06-29-2006, 04:36 PM
RE: fuel filter
took me like 5 minutes to do mine. theres a clamp to unscrew, then 2 plastic clips to pull out. lots of rags would help.
RE: fuel filter
How hard is it to install a cable.
RE: fuel filter
Ya I mean lots of rags! I smelt like gas for 2 days and I took a shower right after I did that. Talk about a headache!
06-29-2006, 05:07 PM
RE: fuel filter
just disconnect the shut off switch in the trunk and run the engine for a few seconds, that way you won't get sprayed
06-29-2006, 06:09 PM
RE: fuel filter
Yeah, you are supposed to relieve the pressure before you change the filter.
-Mark
06-29-2006, 06:46 PM
RE: fuel filter
There is a valve by the fuel injectors on the rail. Looks like a tire valve. Let the pressure out there then you won't get soaked with gas.
06-30-2006, 01:46 AM
RE: fuel filter
my car sat for a week before i did it... so the pressure bled off
GimpyHSHS
19
12-19-2023 01:12 PM
4cylinderplus2
10-09-2020 07:45 PM
Sixx
10-05-2015 07:36 PM
svfetter
10-05-2015 11:39 AM
mrappe
09-26-2015 10:16 AM
