cams
Old 07-03-2006, 01:06 AM
Aixtreme89
Aixtreme89's Avatar
Default RE: cams
I installed my "stage 1" cams from comp cams... XE-262 if I remember.. Yes they require new vslve springs. Any cam that has .550" lift needs new valve springs. I didnt degree the cams or anything I just marked the slot on the chain where the cams where origanally at and in relation to the crank and I swaped them. I used a special spring compressor for replacing the valve springs. So everything cost me about $1000 for the cam swap. Frankly, I wish I went with stage 2 cams, but they wre out of stock when I was looking for them, and I was leaving so I was under time constraint. My stage 1's cut off at 5500rpm. I rev up to 6300rpm. Stage 2 would have sounded better and would have pulled until redline..
Aixtreme89 is offline
Old 07-03-2006, 01:10 AM
2000GT4.6
2000GT4.6's Avatar
Default RE: cams
ORIGINAL: Aixtreme89
I would be pretty interested to see your before and after dyno sheets. Your car should still be pulling at 5500~ RPM even with the stage 1 cam.
I know I didn't pick up anything significant until about 5500. I was acutally pretty disapointed with my cams other than the sound. All of that changed with the blower install, they really made a crapton of power once the boost was flowin.
2000GT4.6 is offline
GimpyHSHS
19
12-19-2023 01:12 PM
Stone629
The Racers Bench
66
06-02-2016 09:52 PM
patchshaffer
Tuner Central
10-05-2015 02:24 PM
uedlose
The Racers Bench
10-01-2015 08:31 PM
junior04
09-28-2015 10:53 AM
Quick Reply: cams
