why only 1 wheel spinning?
RE: why only 1 wheel spinning?
ORIGINAL: dstangrunner
Would it be that the posi is not working?
-P.
Thanks for clearing that up. Learn something new everyday
ORIGINAL: P Zero
Posi = chevy, tractionLok=Ford. Anyway,it sounds like your rear end is workin right. Take it back to the dealer, it should still be under warranty. Tell them on wet (slippery) surfaces you have trouble gettin goin and that only one tire is spinning. Its possible they stuck the wrong center section in your car. Not probable, but not impossible either.
-P.
-P.
That's odd, I have the same situation. I have an automatic and when I would get on it around corners my passenger tire would only spin. Now when I push the brake in and romp the gas both wheels spin. [sm=dontgetit.gif]
ORIGINAL: jkgt3
You have just discovered the wonders of Limited Slip...
JT
