shopping for gears
Old 07-06-2006, 04:26 PM
2VNA
2VNA's Avatar
Default RE: shopping for gears
But in those kits if you get the motives there not the performance plus, you can get the gears with the 6% and the tuner for less then the ket
2VNA is offline
Old 07-06-2006, 04:30 PM
01and96stanggt
01and96stanggt's Avatar
www.50resto.com has frpp 4.10 and 4.30 gears for 169.99, thats the cheapest i've found for ford racing gears, don't know about motive always heard to go with ford racing so i did
01and96stanggt is offline
Old 07-06-2006, 04:42 PM
2VNA
2VNA's Avatar
You can get the tuner for 399.99 - 50.00 so 344.99 and the gears for 159.99 so for +6%off so for around 500 you have your set up.
2VNA is offline
Old 07-06-2006, 07:53 PM
sweet99
sweet99's Avatar
ORIGINAL: 2VNABut in those kits if you get the motives there not the performance plus, you can get the gears with the 6% and the tuner for less then the ket
What's the "performance plus"?
The RPMoutlet.com kit has your choice of tuners, the ring and pinion AND the install kit for $449. Shipped. Still the least expensive. FRPP sells some gearsets which are the Motives. If the part # starts and/or ends in an M then you are getting Motives anyways. I did a search for Motive Gear and there was a thread Motive=FRPP. The other supplier has a part # with either an "A" or a "V" in the part #. Jeg's get's $149.99 for 4.10's and $184.99 for Ford Racing gearsets. Having Ford using Motives makes it tough to choose. I would not mind paying RPMoutlet an extra $50. if I knew I was getting a gearset that would not whine. My mechanic, who has installed several motive gearstes, said it's about 50/50 for the percentage of getting noisy gears. Like flipping a coin!
The tuner would do the speedometer calibration also. I am still leaning towards the RPM kit and the SCT tuner and 4.10's w/install kit for the $449. delivered. What is the preferred gear oil, synthetic or regular and which brand? Thanks, Mark
PS: Summit has the exact same part # for their Ford Racing 4.10 gearset, M-4209-G410A, for $209.88
sweet99 is offline
Old 07-06-2006, 07:57 PM
silversol81
silversol81's Avatar
thanx for all the info guys. i think i am gonna go with 4.10's. just not sure what brand.
silversol81 is offline
Old 07-06-2006, 07:59 PM
40thgtfl
40thgtfl's Avatar
anyone use pro 5.0 gears?
40thgtfl is offline
Old 07-06-2006, 08:00 PM
2VNA
2VNA's Avatar
I would use RP royal purple, the regular motave gears 410's are 129.00 and the performance plus are 159.00. check this link
http://www.mustangtuning.com/rearend.html
2VNA is offline
mtgldr
02-03-2024 09:00 PM
Boostaddict
2.3L Eco-Boost Tech
11-24-2015 06:11 AM
67LimeCoupe
09-30-2015 04:46 PM
ccdguy
09-19-2015 05:20 PM
Pyrate Dave
09-10-2015 07:30 PM
Quick Reply: shopping for gears
