Comp or Vt cam
Comp or Vt cam
Hello,
I am looking to step up from my stock cam to either a comp or vt cam. I am looking at the comp 102100 or the vt stage 1 which does not seem to extreme considering I live in california with the tough emission laws. Does anyone have experience with either of these and was there a difference after it was added?? The other question I have is will these work ok with stock springs, etc.??Thanks all
RE: Comp or Vt cam
VT
Work with stock valve springs. RPM Range 2500-5500. Noticeable idle. Tune suggested. Gains of 25-30rwhp. 540/550 lift, 224/226 .050" duration, 110 LSA
Comp
Brand: COMP Cams
Product Line: Competition Cams Xtreme Energy Camshafts
Cam Style: Hydraulic roller follower
Basic Operating RPM Range: 1,200-5,200 RPM
Intake Duration at 050 inch Lift: 224
Exhaust Duration at 050 inch Lift: 232
Duration at 050 inch Lift: 224 int./232 exh.
Advertised Intake Duration: 262
Advertised Exhaust Duration: 270
Advertised Duration: 262 int./270 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.500 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.500 in.
Valve Lift with Factory Rocker Arm Ratio: 0.500 int./0.500 exh. lift
Lobe Separation (degrees): 114
Intake Valve Lash: 0.000 in.
Exhaust Valve Lash: 0.000 in.
Computer Controlled Compatible: No
Grind Number: XE262H-14
Quantity: Sold as a pair.
Camshafts, Hydraulic Roller Follower, Advertised Duration 262/270, Lift .500/.500, Ford, Modular V8 SOHC, Pair
Comp
Brand: COMP Cams
RE: Comp or Vt cam
I have had both and both gained good HP but the VT's are a little more user friendly. You can get away with a basic install with VT cams as apposed to Comps since most of them have advanced timing ground in and can cause PTV if not properly degreed in.
RE: Comp or Vt cam
ORIGINAL: JimboGT01
what does it take to install cams?
RE: Comp or Vt cam
ORIGINAL: droptoppony
you can do it 2 ways. Remove the timing cover and retime everything...this is the long was but propper way. Or you can use the Aderson Ford Cam install tool and just remove the valve covers and slide them in. I would not do it this way with Comp cams but many have done this with VT st 1's.
ORIGINAL: JimboGT01
are you a technician? Or just a very skilled hobbiest? I could do a lot more work on my car, but don't have the time, tools or location. The skill is there but that's 1/2 the battle
RE: Comp or Vt cam
ORIGINAL: monkeydude3
ORIGINAL: JimboGT01
