grill delete ???
grill delete ???
i tried to remove my grill last night and i couldnt get a wrench to bite on those little nuts on the under side of the bumper. any tips on how to get at them? or anything else that might help me?
RE: grill delete ???
It's a 7mm nut. I used a really small 7mm socket and socket wrench and still had a tough time getting them off. You just need to bend the bumper out to allow more room.....i still have a scar on my finger from it rubbing against the bumper while I was removing the nuts [:@]
the amount of time u spend gettin those damn bolts off u could of pulled the bumper off
i tried the whole get the bolts out and said screw it and pulled bumper cover off...took 10 minutes if that
just take the 2 nutz off one side of the bumper and a couple push pins under the bumper and you will reach easily without taking the whole bumper off. Sounds like more work but once you do it you will seen its very simple. I just swapped to a 04 cobra bumper with delete grill.
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
