3:73's?
Old 07-12-2006, 11:07 PM
  #21
RipTide7
RipTide7's Avatar
Default RE: 3:73's?
i dont like the idea of my car dieing at 110-115 mph with 4.10s. Anyone know the top end with 3.73s?
RipTide7 is offline
Old 07-12-2006, 11:10 PM
  #22
alfromcal846
alfromcal846's Avatar
Default RE: 3:73's?
the best solution ford should have done with the tranny is make the gts 6 speed
alfromcal846 is offline
Old 07-12-2006, 11:14 PM
  #23
CrazyHorse0217
CrazyHorse0217's Avatar
Default RE: 3:73's?
Cannot wait to get 3.73's to go with the auto and s/c. But right now that would void the Roush warranty.
CrazyHorse0217 is offline
Old 07-13-2006, 05:19 AM
  #24
myk
myk's Avatar
Default RE: 3:73's?
ORIGINAL: demon_head
I'm at about 3,000rpm at 80mph, which is high enough for me, and here 80mph is slow on the interstate.
Yeesh. That doesn't sound very appealing at all. A better ratio is always welcome from stock but I couldn't handle 3K at freeway speeds...
myk is offline
Old 07-13-2006, 09:14 AM
  #25
04BlueGT
04BlueGT's Avatar
Default RE: 3:73's?
ORIGINAL: sprostang
ORIGINAL: Stang0005
i also forgot to mention i do about an 8 hour drive home from school every other month
Just dont drive too fast on the highway.
When i`m on the highway, I keep it between 65 and 70 and I still average 20 mpg.
That's what I get city. Highway, I'm 28+.
04BlueGT is offline
Old 07-13-2006, 11:08 AM
  #26
PushinTheLimit
PushinTheLimit's Avatar
Default RE: 3:73's?
If you want to see what your RPM's are gonna be with either the 3.73's or 4.10's... theres a really good calculator for that posted in the stickies. I would check that out if you know the tire size dimensions that you're running. This will give you a better idea at what you would be running at a certain speed. Like some have said on here... 4.10's are good if your interested in pulling off from a line and doing a lil racing on the low end, but your gonna suffer at the top end some. With 3.73's, you won't pull as hard off the line... but your gonna get a lil more top speed out of it. But honestly, not many people drive over 110 anyways so my choice would be 4.10's unless you plan on getting a supercharger. If you had 4.10's and a S/C, you will have a hard time putting all that power to ground without spinning like crazy. Hope this helps.
PushinTheLimit is offline
Old 07-13-2006, 12:02 PM
  #27
GodAmGT00
GodAmGT00's Avatar
Default RE: 3:73's?
ORIGINAL: myk
Why not?? RIGHT in the power band... If you take care of your car and engine, 3k RPM's isn't bad at all... It's crusing at 5200 RPM's, w/ flaky injectors and fuel pump, while your shocks and springs are shot out..
If you're only making a few hundred mile trip once every couple of months, 4.10's will be fine... Just save your pennies...
JT
GodAmGT00 is offline
Old 07-13-2006, 12:19 PM
  #28
Brute03
Brute03's Avatar
Default RE: 3:73's?
ORIGINAL: goldeneagle_10
i would love to hear your explanation of how the top end would suffer with 4.10's, i'm sick and tired of hearing this crap! [:@]
Brute03 is offline
Old 07-13-2006, 02:31 PM
  #29
03truebluegt
03truebluegt's Avatar
Default RE: 3:73's?
+1 With 4.10's and everything else pretty much stock, you will actually be able to achieve a higher top speed because stock the Mustang cannot max itself out. With 4.10's your car still has the potential to do 150+MPH so i really wouldn't be worried about your top speed unless you plan on going faster than that!
03truebluegt is offline
Old 07-13-2006, 02:49 PM
  #30
LvGordo
LvGordo's Avatar
Default RE: 3:73's?
i want to take my 410s out for 373s, i want the extra highway speed in 4th, plus traction in 1 & 2 with the vortech is tough to find when pushing it. For n/a, i would still do 410s, unless you like to race on the highway, then i would do 373s.
LvGordo is offline
Quick Reply: 3:73's?
