What about 3.90 gears?
RE: What about 3.90 gears?
ORIGINAL: 03sonicgt
Because ford racing does not make a 3:90 gear, only motive and richmond do. And I personally wouldn't buy any other brand of ring and pinion.
+1
took the words out of my mouth.
Here is my experience with 3.90's. I have had two set installed and have delt with a nightmare. 3.90's are made by motive or Pro 5.0. I had motive's. The first set i had installed they whined like a bitch. The installer i used has done hundreds of gear installs, but unfortunately all FRPP. I had them replaced under warranty with another set. This time i went to a different performance shop. The result was the same. They whined even worse then the second set. This guy also is a Ford certified master tech and has done hundreds of installs. I couldnt handle it anymore and just put in FRPP 3.73's because i just bought a vortech. Finally peace and quiet. The problem with the 3.90's is that Motives tolerances are so freaking tight that the gears have to be setup PERFECTLY. Even though ford recommends a certain range for the backlash, motive's have to have PERFECT gear tooth overlap. Even if they are slightly off, they will whine. FRPP there is a lot of room for slack and they will still be quiet. The motive's have to be a trial and error process where you have to put them in and check the tooth overlap and if not perfect re do them with different shims. Well, a lot of installers are lazy and just call it good enough because FRPP's you can do that. But not with motive's. So unless you are positive that your installer is great, i wouldnt risk it. Just my 2 cents
ORIGINAL: MustangChris04
Finally! Somebody on mustang forums understands that we need more top end than 4.10's.
I could understand why they like them because they all go to the track. But I went to moroso once and I hated it, they didnt prep the track and the later it got the more dew there was on the track. I can see why so many people in south florida like to street race because there is nowhere else to do it.
as for the gear choice i am going to try the pro 5.0 3.90
i decided to go with 4.10s, so i have a brand new set of motive 3.90s for sale on ebay http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMESE%3AIT
KingRando
10-02-2015 08:06 AM
junior04
09-28-2015 10:53 AM
