idle pulley + belt tensioner - MustangForums.com
Old 07-15-2006, 07:31 PM   #1
ackuric
Default idle pulley + belt tensioner
my idler pulley wiggles ever so slightly, should i replace it?
also is there a way to test your belt tensioner, does it require a certain amount of torque for it to begin loosining tension. im sure its normal but when under the hood, in park, the tensioner gives a lil bit when given gas, which i can see as normal, since its given a load. it definitely doesnt make the belt slip.
ackuric is offline   Reply With Quote
Old 07-15-2006, 07:38 PM   #2
GT_Bob
Default RE: idle pulley + belt tensioner
Idler pulleys will wiggle a little. As long as it is not making any noise or seizing up, it's fine. It is absolutely normal for the belt tensioner to give and take a little under acceleration.
[sm=hiya.gif]
GT_Bob is offline   Reply With Quote
Old 07-15-2006, 07:40 PM   #3
ackuric
sweet thanks for the quick and awesome response. now go answer my motor mount questions =p
Old 07-15-2006, 09:40 PM   #4
99gtstang
99gtstang's Avatar
I had to replace both of mine... around 105K... also in my truck with 48 k on it... ford is bad with ... idler and tensioner pullies.....
99gtstang is offline   Reply With Quote
TNT, New PB TCStangerv6 Street/Strip 12 10-11-2015 06:57 PM
Starting Issue svfetter 5.0L (1979-1995) Mustang 9 10-05-2015 12:39 PM
Rough idle and vibrating 4cylinderplus2 V6 (1994-2004) Mustangs 9 09-30-2015 06:26 PM
I did a Video on Measuring for a New Serpentine Belt after a Smog Pump Delete on a 95 autoedit General Tech 0 09-27-2015 07:37 PM
91 vert tailpipe smoking MacSerio 5.0L (1979-1995) Mustang 3 09-27-2015 02:05 PM
2006, belt, gt, idle, idler, mustang, pulley, pully, tenisor, tensioner, wiggle
