HELP??? A/C in FL not working????
I just charged my A/C and its still blowing hot air? With my 96' Cobra running and the A/C on max the A/C clutch will engage then disengage. I dont know anything about A/C units. Can anyone help it was around 92' here in Florida today!!!
Thanks For Your Help- Brandon - Jacksonville FL.
RE: HELP??? A/C in FL not working????
Did you actually see the clutch engage then disengage? Sounds like maybe the low pressure switch (which disengages the clutch). As for 92 degrees, it's 100 here in Texas right now, with a heat advisory until 11:15 tonight. I'm glad I got my A/C patched up. Good luck.
ok.... I did the resister test, I stuck a paper clip into the plug, and the compresser stayed engaged. But... the air did not get cold at all??? I dont know what to check next?
Thanks For All the Help- Brandon
09-01-2015 08:16 PM
