Installed MAC cold air then service engine light turns on?!?
Old 07-18-2006, 12:32 AM
acbruno
acbruno's Avatar
Default Installed MAC cold air then service engine light turns on?!?
I have a 2000 GT with a MAC pro chamber and MIL eliminators. I’ve been running this setup for a few months with no problems. Yesterday, I installed a MAC cold air intake. I drove it five miles no problem, then on the way home the check engine soon light came on. I assume it has something to do with the cold air install. I installed it per manufacturer specifications. Any ideas?
[IMG]local://upfiles/42865/91BE653E141A4AA7A3F055038D2C280B.jpg[/IMG]
acbruno is offline
Old 07-18-2006, 12:43 AM
Cornbread01
Cornbread01's Avatar
Default RE: Installed MAC cold air then service engine light turns on?!?
check the conection on the maf.... but first did you unplug the battery for 5 mins before driveing and also it could be your mil eliminators i heard the tend to fail but start with the battery disconect the reconect after five mins
Cornbread01 is offline
Old 07-18-2006, 12:45 AM
wes ley n the G T
wes ley n the G T's Avatar
Yea you might need to clean your MAF. Also make sure theres no vacuum leak with the IAC tube and pcv tube coming off the CAI
wes ley n the G T is offline
Old 07-18-2006, 01:03 AM
rjgstang
rjgstang's Avatar
ORIGINAL: Cornbread01
+1 try the battery, it should have been disconnected upon install if not then try now.
also, clean that motor up, that bitch is nasty lol!
rjgstang is offline
Old 07-18-2006, 01:16 AM
acbruno
acbruno's Avatar
Yeah, it's a bit dirty but the MAC dresses is up a little bit. I was told to disconnect the battery for a few minutes. I'll try that first and see what happens.
I cleaned out the IAC last week. Couldn't get it to idle. That seemed to fix the problem.
I'll try cleaning the MAF if nothing else works.
No vaccum leaks that I know of.
Thanks for the quick replies. You guys don't mess around!
Later
acbruno is offline
Old 07-18-2006, 01:51 AM
Blck98GT
I ♥ Acer
Blck98GT's Avatar
like everybody else said.. battery.. then check the MAF. Hope everything turns out alright.. let us know.
Blck98GT is offline
Old 07-25-2006, 07:40 PM
acbruno
acbruno's Avatar
I disconnected the battery for an afternoon then took it out for a drive. It worked for a while until I noticed my AC wouldn't turn. Then moments latger the service engine light came on. I slowed to a stop then suddenly the AC kicked in. The engine runs fine. I'm thinking I must have a vaccuum leak. Those blue hoses that came with the kit might not connect tight enough, so I might put on some hose clamps to see if that helps. Any other ideas?
acbruno is offline
djbigskrilla
09-20-2022 01:04 AM
MXBT187
08-20-2015 02:36 AM
kevans79@yahoo.com
08-18-2015 08:16 AM
drumhedd2005
08-13-2015 09:59 AM
HIS S-197
08-10-2015 05:47 PM
Quick Reply: Installed MAC cold air then service engine light turns on?!?
