[Deleted]
RE: UPR x-pipe
Take a look at this. He is using it and I assume its doing good. http://www.03cobra.net/html/modifications.html
RE: UPR x-pipe
Im running the UPR x-pipe. I dont really think it matter in terms of name, because its just 2 pipes welded together in the shape of an X. I bought it because like you said it was cheap. Plus you get a discount if youre a mustangforums member. 10% i think. You can also check out mustangtuning.com because they offer no charge on shipping. You might be cheaper going with them. My x-pipe didnt fix exactly. Make sure you have heat because the exhaust mainfold bolts dont come off easy. be sure not to break them off. Then it fit ok, but it hit against my trans mount, so i heated it up and put a dimple on the x-pipe and it fix perfect besides that. Make sure you buy O2 elimators because youre mustang wont run correctly without them. I bought those from Mustangtuning also. But they sent me 2 of the same side o2, so i had to snip off the connector notches and they fit after that.
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
