What size cams do I need for a 2v 4.6?
Old 05-24-2004, 11:37 PM
jdaniel
I ♥ Acer
jdaniel's Avatar
Default RE: What size cams do I need for a 2v 4.6?
And what does that run to get it done and how long will it take?
jdaniel is offline
Old 05-24-2004, 11:40 PM
mdvaldosta
I ♥ Acer
mdvaldosta's Avatar
usually a couple hours by the time you include the setup etc. Most places are around $300.00 or so - you gotta pay the tuner + setup + dyno time
mdvaldosta is offline
Old 05-24-2004, 11:43 PM
jdaniel
I ♥ Acer
jdaniel's Avatar
Awsome, i'll get that done next. Is that a good gain in power or just something that needs to be done?
jdaniel is offline
Old 05-24-2004, 11:46 PM
mdvaldosta
I ♥ Acer
mdvaldosta's Avatar
don't go getting a tune until you gets your mods pretty much done with, or you get a mod that cant be right without a tune (like a cam or most supercharger setups). Really, they may pull an extra 10 hp out but EACH session is gonna cost bucks $$$$, and every mod you do after the tune will throw off what you paid for. Even something like exhaust work can change your a/f ratio. Best get that tune once you get cams in or your mods pretty much done, either that your you have lotsa $$$ - in that case just give it to me :P
Old 05-25-2004, 12:05 AM
jdaniel
I ♥ Acer
jdaniel's Avatar
well I just ordered a 85mm pro am MAM to go along with my drop, short throw shifter and timing adjuster. I think thats all im gonna do fo a couple or few months. Im gonna think about it.
jdaniel is offline
Old 05-25-2004, 12:10 AM
mdvaldosta
I ♥ Acer
mdvaldosta's Avatar
That will go good with your denscharger Now a throttle body and upper plenum would actually be beneficial in the future
Old 05-25-2004, 12:11 AM
cableguy
cableguy's Avatar
i'm having cams installed right now, should have it back thursday. i went with comp cams high energy street/strip cam grind #xe278h it has a valve lift of .550, and duration of 242 in, 246 ex. i bought them at modular depot motor sport for $550, the springs were $185.in order to use the street/strip cams you need 3.73 or higher gears, aftermarket intake and exhaust. and a chip dyno tuned. i bought the chip from md motorsport as well for $325, which comes tuned to your specs.
i have a 99gt with densecharger c.a.i., 70mm accufab t.b and plennum, steeda pullies, port polish heads, comp cams, frpp headers, bassani xpipe, magnaflow cat back and frpp 4.10's
the cams i'm told will give it a rough idle, which will sound like a true muscle car. i'm looking at 300rwhp or more. will post video when i get it dyno for exact hp.
cableguy is offline
Old 05-25-2004, 12:46 AM
jdaniel
I ♥ Acer
jdaniel's Avatar
Awsome, I would love to see it get dyno'ed. Make sure you remember to post it!
jdaniel is offline
10-09-2015 03:27 PM
vintageaion
09-08-2015 10:45 AM
mustangrob
12-03-2005 01:18 AM
Djs94stang
04-08-2005 10:44 AM
zGOTxBOOST2
02-12-2005 09:55 PM
Quick Reply: What size cams do I need for a 2v 4.6?
