X PIPE WITH CATS! IS IT WORTH IT?
I have a 99 mustang gt 4.6 SOHC. I wanted to get off road X Pipes but I have stupid E-Check to deal with. I was going to purchase it anyways but to swap it out on E-Check day I don't know if the off road is worth it because I would have to pay $96 to each time I swap them which means I will be paying a little over $200 after tax every 2 years when stupid E-Check comes Around. I HATE E-CHECK. So i was wondering If I bought the X Pipe with cats is it worth it? I have flowmaster american thunder system right now so would the catted X pipe make it louder and would i get any more HP out of it? The only thing i have done to my car is the American Thunder Flowmaster system, a BBK cold air intake and throttle body spacer. So with just these parts installed will the X Pipe w/cats help at all or is my car already breathing good enough since there is nothing bored over? If you have any other suggestions let me know. Thanks
RE: X PIPE WITH CATS! IS IT WORTH IT?
There are several X-pipes that have removable cats. This means that you can put the straight tubes in their place when e-check comes around, and then swap them back out. Its a matter of 2 clamps per side so I wouldn't pay $96 for the swap. I had swapable ones but I eventually just decided to weld the cats on because the power difference was inconsequential to me. It didn't actually FEEL any faster without cats (just dynoed slightly better) and I didn't mind the sound difference.
did you have an aftermarket exhaust before you installed the X pipe? because i am trying to figure out wether I am going to get more sound and hp because with the flowmasters it sounds good but i want it to be louder. And thanks a lot for helping me out fallstar you have been helpful
Well I bought the car like this, but I have a friend that has almost an identical setup but without long tubes. He first got flowmasters and had them for a little while and it wasn't nearly as loud until he got an x-pipe.
That's pretty much all that's been done to it that I know of. I'm taking it to a shop tomorrow to find out everything that has been done to it. I suspect the clutch has been changed to an aftermarket, and the gears have been changed probably as well.
ORIGINAL: DROES99STANG
what is the air silencer? is that the thing in the air flow box? (factory intake)
