how much power can i push?
Old 07-26-2006, 03:52 AM
racer02GTstang
racer02GTstang's Avatar
Default how much power can i push?
i was wondering how much power can i get out of this setup...
vortech supercharger aftercooled with 17psi
full exhuast
throttlebody/ upper plenum
stage 3 VT blower cams
stage 2 Vt heads
4.6 forged lower end with billet rods
possibly a p51 intake eventually
im just wondering what will i need to support this... how much power should i see... any other reccommendations that i can do? this is what im thinking of doing... i am attacking the motor next and want to get the heads, cams, and short block... it should be pretty stout then...
racer02GTstang is offline
Old 07-26-2006, 04:36 AM
rjgstang
rjgstang's Avatar
Default RE: how much power can i push?
my guess would 550hp+
rjgstang is offline
Old 07-26-2006, 05:43 AM
PWORLDSTANG
PWORLDSTANG's Avatar
At 17 PSI? .... A LOT! ...Is that a typo?
PWORLDSTANG is offline
Old 07-26-2006, 06:44 AM
dvs_03gt
dvs_03gt's Avatar
stock internals are safe up to 400hp youd say? or more?
dvs_03gt is offline
Old 07-26-2006, 06:51 AM
1BAD3V
1BAD3V's Avatar
Stock internals can hold around 450rwhp, but that is about all. If you build an engine to be able to push 17psi safely, than I can serious see about 600rwhp. But be sure to work on the suspension, you could have 600rwhp and only run 13's without the right suspension. Good luck with your project, once finished it should be badass.
1BAD3V is offline
Old 07-26-2006, 09:27 AM
GodAmGT00
GodAmGT00's Avatar
It depends on the efficiency of the SC, and the Intercooler... Also, it depends on the actual airflow you achieve w/ all of it put together..
It's tough to guess, since you also didn't mention compression Ratio, RPM range, head work (cut valves, doming head, etc...).
JT
GodAmGT00 is offline
Old 07-26-2006, 02:42 PM
racer02GTstang
ORIGINAL: 01SilverGT
my best so far is like a 12.6 spinning on drag radials... haha. i bet i will run a high 12 with like 10 or so more mph added to the trap speed. suspension may get some work with the motor build... i have been thinking of a tubular front suspension with coil overs.
Old 07-26-2006, 02:44 PM
racer02GTstang
ORIGINAL: GodAmGT00
JT
im going to run stock compression (9.3-9.5?), probably up to 7,000 rpms. im not so sure on the headwork. the cam they say is good for 3500-6500+ rpms.
racer02GTstang
ORIGINAL: PWORLDSTANG
nope, no typo... im going to have a built lower end... i want this bitch to fly... haha.
Old 07-27-2006, 02:07 AM
BCisme
BCisme's Avatar
what blower do you have? with a T trim pushing 17 psi, you can see upwards of 650 with the right fuel system and tuning. a TKO 500 might not last long though. suspension is a must. if you have V-2 trim, you might be able to get 600 hp. but remember, with ported heads you lose boost, as pulleys are designed to flow through stock heads. so to see 17 psi, you'd prob have to put a 19 or 20 lb pulley on it.
i hope you got alot of money. my motor is built, heads/cams are done. drivetrain parts are in. after all is said and done i'll have spent over 20 grand, mostly on the engine drivetrain and power adder setup. not including stuff i've already done to it, recurring expenses like yet another shortblock swap, 3rd set of cams 2nd set of springs 4th dyno tune etc...
BCisme is offline
Quick Reply: how much power can i push?
