diablo tuner
Old 07-26-2006, 09:51 AM
johhnykiller111
johhnykiller111's Avatar
Default diablo tuner
I am not sure how to turn off the rear O2 sensors on my car I went through the diablo manual and it had 2 things on each side and I could only find 1 the obdII test or somting like that and the other that it said i had to shut off was heatpack I and II or somthing like that I was wondering if that was for automatics because i also realized that i can't turn off my traction perminatly because i have a manual
johhnykiller111 is offline
Old 07-26-2006, 10:11 AM
grey02GT
grey02GT's Avatar
Default RE: diablo tuner
I have the diablo tuner and when going through the on screen menu i remember seeing an option to turn off the O2 sensors. I Havent turned them off b/c I dont have a OR H pipe yet so someone else might be able give you more insight but my Gt is manual and I can tell you that you can turn the traction control off permantely.
grey02GT is offline
Old 07-26-2006, 10:23 AM
sweet99
sweet99's Avatar
ORIGINAL: johhnykiller111I am not sure how to turn off the rear O2 sensors on my car I went through the diablo manual and it had 2 things on each side and I could only find 1 the obdII test or somting like that and the other that it said i had to shut off was heatpack I and II or somthing like that I was wondering if that was for automatics because i also realized that i can't turn off my traction perminatly because i have a manual
Directions are clear. Go to modify parameters and when you find OBDII you Turn all of the following to "OFF". OBD-II MIL/OBD-II test/heater bank 1 downstream/Heater bank 2 downstream/o2 config.
sweet99 is offline
Old 07-26-2006, 10:30 AM
johhnykiller111
But I can only find the OBD - II test I can't find anything else
Old 07-26-2006, 10:35 AM
sweet99
sweet99's Avatar
ORIGINAL: johhnykiller111But I can only find the OBD - II test I can't find anything else
On the screen for OBDII there must be a drop down for each:
EGR switch
o2 sensor congig, ect. Hit ESC from the OBD-II and see if it gives you another parameter to turn off. If you still have trouble I will plug mine in and see what needs to be done to find the others to turn off, just let me know. Mark
PS: When you come to the OBD-II hit the center button between the arrows as that may drop down the rest you need to turn off.
sweet99 is offline
baddog671
07-26-2016 01:20 PM
04stangman
09-17-2015 01:45 PM
nboost
09-16-2015 05:35 AM
ernesto-619
09-10-2015 01:32 AM
Webster454
09-07-2015 04:59 AM
Quick Reply: diablo tuner
