The purpose of Control Arms?
RE: The purpose of Control Arms?
ORIGINAL: joeybutts
What exactly do control arms do? I know they help your car hook up better, but how? And where do they go? thanks!
Well, look at the name, and take it for what it is...
The Control arms, help you control lateral and axial motion.. Front control arms help you control the steering of your car.. Rear control arms help you control the rear tires and their aspect to the road...
Your lower control arms (being lower than the Uppers [8D]) are perpendicular to the rear axle, located towards the outer ends/tires. These have the rear spring perches on them. The Upper control arms, are at about a 45 degree angle, from about where the middle of the rear seat, down to the axle.
Hope that helps..
JT
Hope that helps..
JT
ORIGINAL: joeybutts
So they better position the axles under the car? how does this help the car get better traction though?
The control arms don't rotate, per se.. As you drive, they are continuously moving though, up and down. When they work together, you can get better angles, and more rotational axis, than if they were solid, or only moved one at a time..
JT
JT
ORIGINAL: joeybutts
Do the control arms physically move/rotate so as to keep the axles in one position? And therefore allow the tries t okeep pressure on the ground?
Got it! Now, my last question....what makes aftermarket control arms better than stock ones? If it is something that has one motion how much can you improve upon that besides weight reduction? Or is that where the bushings come in?
