another intake manifold
http://dagostinoracing.com/index.php...oducts_id=7409
anyone know about this intake? looks similar to the edlebrock on but it comes with the tb adapter all for 800
i searched that part number on fordracingparts.com and it didnt come up with anything
RE: another intake manifold
The problem w/ that is, they could design something that worked well in the mid-range, but then you'd lose some of our already anemic bottom end , and you'd lose all of the top end..
A manifold that was designed for the RPM range I believe your thinking of, would be sort of, well, a waste.. It's been proven that our intakes, however weak in material, are good to 500+hp w/ out sacrificing anything but a little bottom end?? Why mess up a good thing??
You'd be better off making your engine utilize your current RPM band, and if you want to go bigger, then move on up to something like the P-51, or Edelbrock..
JT
JT
i havent seen a good intake yet... that intake looks like it is meant to fit a carb on it.... but then i see it says its got like an elbow for the tb. looks more like a mid range power manifold... may do good with a boosted car though, seems expensive though for its style... something like that for like a normal non modular motor is under 300.
If you look at the small picture on the top left hand side, it shows what looks similar to the Accufab Upper Plenum, and you get a TB Adapter plate, I believe. I didn't Click to Enlarge. Not too bad of a deal. I wonder if you get gaskets too...
The good thing though, about this specific intake, is you can extrude hone it a time or 2 over, and really make it worthwhile.. Screw porting that much metal, unless you had a lot of time on your hands, and a few machine shop tools to help...
JT
JT
ORIGINAL: GodAmGT00
Well isn't that special??
The did mention that you get the upper Plenum as well... Still not too bad of a deal...
It almost looks like the Edelbrock Performer Intake for the carbed guys..
JT
JT
or this edelbrock intake for the 4.6 sohc
http://www.edelbrock.com/automotive_...lds_ford.shtml
